Ok....The 3.5 liter in the malibu has 200 HP and the malibu is about 3400 pounds. With a 4 speed automatic is gets about 32 MPG and goes from 0-60 in a hair under 8 seconds. The toyota camry has 225 HP, and weighs about 3400 pounds. with a 5 speed automatic, it also goes from 0-60 in a hair under 8 seconds, and gets 29 mpg.quote:
Originally posted by kenw:
quote:
Originally posted by T-Keith:
quote:
Originally posted by Spitty:
quote:
Originally posted by sbc350gearhead
Pushrod engines usually get better fuel economy than a DOHC engine of the same displacement.That's an interesting idea, can you give an example, you must also consider power out-put.The new Malibu's 3.5 has more power and better gas mileage then Toyota's 3.0.
-Tproblem is, the Toyota 3.0L v6 is 10+ years old. The comparable GM v6 in 1993 was the (bark, bark) 3.1..... ?
OK, that was tacky... let's move up to the GM 3.8L...~20% larger displacement (than the TMC 3.0) and and STILL less HP.....
how many ways can you spell dog???
fast forward to something not 10 years old...
The Toyota 3.0L has been replaced by a 3.3L v6. Which STILL puts out more power (225hp/240#) than the Malibu's "new" 3.5L (200/220#).
and... is still smaller.... [/QB]
A toyota tundra with a 4.6 liter V-8 gets has 282HP and gets 18 mpg. A chevy silverado with a 5.3 liter V-8 has 310 HP and gets 18 mpg, even though the chevy is a much larger and heavier truck.
This isn't my opinion. The same traits that give a DOHC engine an advantage at high rpm, also make it a disadvantage at low rpm as far as torque and fuel economy are concerned.
[ December 14, 2004, 09:01 PM: Message edited by: sbc350gearhead ]
