Originally Posted by maxdustington
2000 lbs would be sufficient.
Jacking one tire at a time is still lifting the weight of half the vehicle (even if the "third" wheel is still on the ground, the suspension on that wheel may be unloaded either partially or completely, putting the full weight of the half of the vehicle you are lifting on the jack).
So, depending on the weight distribution front: rear and the total weight of the vehicle and cargo (because it could be loaded to maximum cargo weight), that would be your jack weight rating, plus the 200% safety margin. The safety margin is required because you never use any injury / fatality potential tool to it's maximum rating.
Eg Miata 2200 lbs + 600 lbs = 2800 lbs, 51:49 ratio so 1428 lbs : 1372 lbs; greater of the two is 1428 lbs x 200% = 2856 lbs, you would select a 1.5 ton (3000 pound) jack.
For the OP's vehicle, 2000 lbs is definitely not sufficient.
