Hi All.
I dont know if there is somebody on the forum with a lot of knowledge in road racing motorcycles? Im kinda new with this and shall give a little explanation of what we plan to do.
We race a Yamaha R6 out of 2008, with extended radiator for better water cooling.
This are 6 sessions, of 20 minutes every 2 hours, so it will cool down, and then go to plus minus 16000 RPM ( programmed ECU )
I think, this will ask for a special oil, and im looking for advice in this.
Mostly, we race in summer time, outside temperature +32 celcius ( 89,6 Fahrenheit )
In the manual, it states: API SG or higher, JASO MA .
When i look at the SEA diagram, the 10w-50 will go to the highest (outside) temperature, makes that the best choice?
Here in The Netherlands, this oil is common used:
Castrol Power1 Racing 4T 10W50
I hope everybody with the knowledge can give his opinion , that will help me with my choice for a great oil
Engine type: | 4 cylinders, 4-stroke, Inline |
Displacement: | 599 cc (36.6 cubic inches) |
Bore × stroke: | 67 mm × 42.5 mm (oversquare - shortstroke) |
Cooling system: | Water cooled |
Power: | 124.68 HP (91.7 kW) @ 14500 rpm (Ram-air) |
Torque: | 69.1 Nm (7.05 kg-m) @ 11000 rpm (Ram-air) |
Valve train: | DOHC, variable |
Valves per cylinder: | 4 |
Sparks per cylinder: | 1 |
Fuel supply system: | Fuel injection |
Ignition type: | Digital CDI |
Funnel diameter: | 38 mm |
Compression: | 13.1:1 |
Engine mounting: | Transverse |
Lubrication system: | Wet sump |
Gear box: | Manual 6-speed |
Clutch: | Wet, slipper, cable operated |
Final drive: | Chain |
Spark plug pipe type: | NGK, CR9EK |
Motor oil: | Synthetic, 20W/40 |
