Originally Posted by Char Baby
We don't know your knowledge of tire psi.
Too much air can cause tire wear in the center of the tread.
Too little air can cause tire wear on the outside/inside edges(shoulders).
I would start with the recommended psi that your vehicle requires(usually listed in the door jamb) for your tire size & speed rating.
Then add small amounts of air to see it your fuel mileage changes. Most likely it won't just from more air alone.
Also, how much of a harsher ride(with more air) can you tolerate?
Do you prefer better/crisper handling & turn-in?
Or a slightly better ride over broken pavement?
These are just some factor to consider.
Not to start turbulence, however, my tires max inflation shows 51 psi and I pump them to 40-42 psi (cold pressure) because I like them stiff, just personal preference. I have never had problems with the center tire wear more than the outter/inner sides of the tire.
