Pretty much correct. I've always done 2oz's at a time, which has not been a lot. A Chevy Nova 10 bolt and a 1974 Z/28, both needed some more friction modifier after I changed rear gear oil. I drove in a figure 8 a couple of times to get it worked into the clutches. Yes clutch material makes a difference. The newer the more you should listen to the manufactor.
