Originally Posted By: deeter16317
OK, shutting down under throttle doesn't bother me...it is completely the opposite of what I've always done. Typically shutting down under throttle (in the older engines) causes worse run on and backfiring!
How do you check the timing, or change the timing? I almost wonder if the timing isn't retard to far? The service manual only indicates checking for timing advance with the "SmartSpark" system. There is nothing about checking or setting timing.
I know it feels hotter than "normal", but its a completely different engine than I have used before so it might be normal for this breed of engine?
It runs like a scalded dog, even full tilt with fairly heavy grass (61" deck); it hardly changes tune.
Things that can effect the timing on that engine are. A sheared flywheel key, wrong gap from the coil to flywheel, and sparkplug gap. But there is no timing adjustment per say.
