Originally Posted By: mjoekingz28
Report back as to which feels warm and which gives you skin burns.
Mola is correct in this regard, but your counterexamples hold true, only because you're ignoring certain assumptions. Some sumps are very exposed to the elements. Some have coolers. Some have, in rare occasions, non-thermostatically controlled coolers.
The old Audi had minor temperature differences between winter and summer, as you note. The G37, though, thanks to the oil pan being hidden away from the elements, and other things, will have high oil temperatures all the time. My last winter oils change was done when it was -34 C. I drove the vehicle from a cold start for only 13 km. I could not touch the oil filter with my bare hands, or even just my gloves; I had to use a rag and gloves. I may be a big baby, but I'm not a big baby about this, since I used to do oil changes on the taxis on the hottest days of the year, after them running all day, and never wore gloves.
Basically, sump temperatures can get as hot, even with differing ambient temperatures. If it were your hypothetical 100 mile run in 20F ambient, with my G37, you wouldn't be touching that filter.
And also, I'd make sure that Mola didn't lay a trap for us.
Quote:
It will take longer to warm up in the winter, but if driven far enough, it will reach the "equilibrium" temperature.
Can the equilibrium temperature fluctuate with the ambient temperature, given those variables I listed above?
