I went to change the oil in new 2015 Forester with 2.5 engine. Its the best setup to change the oil I have come across. The engine has a shroud under it but there is a small cutout for the oil drain plug. Easy to get a wrench in there and drain the oil.
The oil filter and fill were up front on top where other fluid fills were located. The oil filter mounting plate had a shoulder around it about 2" out from the filter so any oil that came out from unscrewing the filter would be contained. There was even a drain hole to catch any oil in the area towards the shoulder (unsure where the drain hold went).
I changed the oil to PP 0W20 and M1 filter at 2234 miles. It requires synthetic.
