Yeah right.... I guess I got to glue it to a piece of cardboard so it does not tip over, and hopefully it does not leak as bad on its' side like the old design did.
....seriously, WD-40 can/bottle designs are going backwards.
I ended up buying an empty WD-40 spray bottle from AutoZone and then filling it up with two cans of SuperTech spray lube from Walmart. The sprayer works real nice. You get your choice of a narrow spray or a wide spray. I use the wide spray. I needed it for my reel mower to spray all over the blade so that it doesn't stick to the bed knife. Works sorta like cutting fluid.
