New 2008 Accent Sedan, 1.6L (again, same as my 2005GT). On every car I ever had, the recovery tank was no more substantial than the W/S washer tank with the same snap on, non-airtight cap as the W/S fluid tank. On this new one, the cap is screw on, has a heavy rubber seal, and the structure of the tank itself is much more substantial and solid. It had a hose nipple for overboard dump of fluid, but even there, it has a substantial widening of the neck exiting the tank making me wonder if there isn't a check valve in there. I know there's expansion and contraction as the level goes up and down with the hot and cold cycles of the engine, but why the heft built into the tank and cap for the puke tank? Is evaporation of coolant an EPA issue now? Or is the isolation from the ambient air a protection for a Dex-Cool style coolant? A hydraulic or emissions-sensor consideration? There are no wires running to the tank that I can see.
The radiator appears to have a standard 13PSI cap, and the syrup inside is heavy, sweet-smelling, very slippery to the touch and very, very blue. I know this is a lot of questioning for a lousy puke tank, but this isn't like anything I ever saw.
