flush and fill Volvo S80
Oakville, Ont., Canada
Hey guys!
For the first time, I'm planning to flush the cooling system of my 2013 Volvo S80 with 120, 000 KMs and here are the steps in my mind.
  1. drain the coolant by opening the petcock
  2. close the petcock
  3. fill the expansion tank with distilled water
  4. run the vehicle for 10-15 min until the thermostat is open
  5. wait till the system to cool down
  6. repeat #1 -> #5 multiple times until the water comes out clear
  7. drain for the last time
  8. fill the expansion tank with concentrate (50% of the total capacity)
  9. top off the system with distilled water to reach 50/50 ratio
Is there anything incorrect or that I missed ? I'm thinking of getting a spill free funnel but wonder If I really need one since the Volvo has an expansion tank? TIA!
I would premix the coolant and distilled water. More accurate.
Not sure if you have the I-6 or the I-5. From my experience the I-5 is hard to get the air out. A vacuum or a metering funnel really helps. Both are simple to use and inexpensive.
@Astro14 has more experience in this area that I do.
Why not drain it all the way? The petcock on the radiator gets about half out. There should be another drain.
Once drained, vacuum fill with 50/50 and you’re done. All the extra water isn’t cleaning anything.
Vacuum fill is the way to go. About $60 for the tool You’ll need a compressor. Fill it once, no air bubbles, and you’re done. No repeat bleeding cycles.
Volvo uses good coolant. It’s good for ten years. Here’s a 19 year old water pump. 234,000 miles, on the left, next to a brand new one. No corrosion. No worries
Unless your existing coolant is discolored and you see other symptoms like your engine overheating there should be no particular use in anything beyond draining out the coolant as far as possible, pouring in a slug of distilled water and draining that and then refilling with coolant concentrate + distilled water that you mix in advance or buy as a premix.
