Hello everyone this UTOA on my 08 Ford F150 5.4v FX4 4x4 with 87,800 miles on the transmission oil, I bought the truck used at about 75k mark and started doing all the maintenance myself, the previous owner did alot of highway driving and minimal towing. He was religious about following the factory maintenance plan with everything and well Ford does not say to change the transmission fluid till 150k, In my own opinion think that is to long. So I decided to drop the pan and change the filter and fluid also clean off the magnet in the pan. By doing this you only get 5.5 quarts out of a total 14 quart capacity transmission when you add whats in the torque converter and cooler lines ect. I replace the filter with a Motorcraft and the 5.5 quarts with Valvoline Mercon V. This UTOA is the factor fill Motorcraft Mercon V. The analyst said the iron was high and the check for abnormal noise/performance. The transmission drives and shifts flawlessly. Any recommendations? Thanks, Cody
Code:
Motorcraft Mercon V
DATE TAKEN 2/7/2012
Aluminum 14
Chromium 0
Iron 150
Copper 146
Lead 33
Tin 8
Moly 0
Nickel 6
Manganese 7
Silver 0
Titanium 0
Potassium 9
Boron 58
Silicon 12
Sodium 10
Calcium 158
Magnesium 1
Phosphorus 175
Zinc 37
Visc 100 C 6.6
Water Negative
Anti- Freeze Negative
Fuel Negative
Code:
Motorcraft Mercon V
DATE TAKEN 2/7/2012
Aluminum 14
Chromium 0
Iron 150
Copper 146
Lead 33
Tin 8
Moly 0
Nickel 6
Manganese 7
Silver 0
Titanium 0
Potassium 9
Boron 58
Silicon 12
Sodium 10
Calcium 158
Magnesium 1
Phosphorus 175
Zinc 37
Visc 100 C 6.6
Water Negative
Fuel Negative
