Hi all,
This the UOA of a Volvo Manual 5 speeds M47 II transmission, mounted on 240/740/940.
This 1994 Gearbox has 332 000 km (~ 205 000 miles), and was quite worn when I get the car at 315 000 km (especially 2nd synchro)
Those gearbox need normally ATF type F but I have done a test with Dexron III during 17 000 km (~ 10 000 miles) to see if it can fit with synchromesh and friction modifier. Shifting was OK.
The result seems to be quite unusable as the Dexron seems to have washed all the old deposits in the tranny, and give now very high metal and insolubles...
Do you think anyway we can conclude the Dexron is no good for the synchro, or cooper/lead/tin are caused by old deposits like iron/aluminium ?
Q8 Auto 15 datasheet
