JHZR2
Staff member
Hello,
Im thinking through the opportunity to get a set of 15x7.5" wheels for my 91 BMW 318i, to replace the 14x6.5" wheels I currently have.
My question here is, will there be any real or perceivable benefit to doing this... and what would be the downsides.
Original setup, p196/65r14 'H' rated tires on 14x6.5 wheels. The wheels weigh a hair under 14 pounds, and the current tires weigh 18.3 pounds. The alternate tires ive seen in that size are all about one pound more.
So the current setup has a weight of 32.3-33.6 pounds per wheel/tire assembly.
The wheels Id be getting, 15x7.5" ronal German-made basketweaves are 17.2 pounds each. Looking at tires in the p195/60r15 size, Im looking between 17 to 21 pounds each (the 21 is for potenza re960AS pole position, which are VERY highly rated at tirerack). Looking at p205/55r15 tires, Im seeing 19-20 pounds.
So, overall Im looking at 34.2-38.2 pounds for the tire/wheel assembly.
Now, let's take midline estimates, so 33 vs. 36 pounds at each corner, will I notice any real effect/degradation due to weight? Im not auto-xing, but spirited driving and going fast around offramps, hard braking, etc may occur.
More importantly, I'd be using a taller rim, and 5-10% less sidewall height. I'd think that this would benefit handling slightly, but given the weight increase, is there any real benefit?
Also, given that I drive on a lot of PA roads which have a lot of roughness and potholes, how big of a ride difference is this going to make? I usually run my pressures a bit higher than spec for fuel economy reasons, but I'd hate to make the car turn into a buckboard because of its light weight, slimmer sidewalls, and high tire pressure.
That said, does higher tire/wheel weight or unsprung weight in general help or hurt the ability to smooth out potholes and bad roads?
Id appreciate any insight on this potential decision that I can make, as it will help me out quite a bit.
Thanks and best regards,
JMH
JMH
