This car had the head cylinder gasket replaced at 23,747 miles in the beginning of September , 2010 due to oil leak from #1 cylinder and no leak as of yet since the repair . Sent the sample to BLACKSTONE LABS on Monday the 9th and received the results today . Here is the report .
Make/Model:
TOYOTA Yaris 1.5L (1NZFE) 4cyl
Oil/Filter:
PENNZOIL Y.B. (conventional) 5w-30(SN/GF-5)
TOYOTA( Denso) 90915-YZZF2
Air Filter:
TOYOTA 17801-0T030 ( installed 9/18/2010 @ 24,359 mis )
Oil/Filter install / removal: 26,435 miles. > 30,945 mis. (11/21/10 > 5/9/11 )
Miles on oil: 4,510
Previous oil/filter : SHELL conventional 5w-30 ( SM/GF-4) , TOYO oil filter
COMMENTS: Thanks for the notes about the work that was done . It looks like all the problems are behind this engine now , at least based on this data . Potassium and sodium both were low here , so we don't think any coolant was getting into your oil . Universal averages show typical wear levels for this type of engine after about 6,100 miles on the oil . Iron was a little high in comparison , but certainly not in the problem range , and the TBN was strong at 2.7 , so lots of active additive was left . 1.0 is low . Nice report .
Code:
Aluminum: 4
Chromium: 0
Iron: 12
Copper: 1
Lead: 0
Tin: 0
Moly : 243
Nickel: 0
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 0
Boron: 87
Silicon: 18
Calcium: 2236
Magnesium: 9
Phosphorus: 708
Zinc: 881
Barium: 1
Sodium : 4
SUS Visc @ 210F : 55
cSt Visc @ 100 C : 8.78
Flashpoint in F : 385
Fuel % :
Antifreeze % : 0.0
Water % : 0.0
Insolubles % : 0.2
TBN : 2.7
Drove the car 18 miles before the oil change to get a good sample . Replaced the PYB/Toyo oil filter with SHELL full synthetic 5w-30 (SN/GF-5)/TOYOTA oil filter and new TOYOTA air filter . Plan to do another U.O.A. of the SHELL synthetic in late October to early November for comparison to the PYB . Here's the UOA for the 2010 3 door YARIS we recently traded in for a HONDA Fit . http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2217800&page=1 .
Make/Model:
Oil/Filter:
Air Filter:
Miles on oil: 4,510
Code:
Aluminum: 4
Chromium: 0
Iron: 12
Copper: 1
Lead: 0
Tin: 0
Moly : 243
Nickel: 0
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 0
Boron: 87
Silicon: 18
Calcium: 2236
Magnesium: 9
Phosphorus: 708
Zinc: 881
Barium: 1
Sodium : 4
Fuel % :
Antifreeze % : 0.0
Water % : 0.0
Insolubles % : 0.2
TBN : 2.7
