Daly, you might drain the engine oil through a coffee filter and try to get an idea of the number and sizes of particles that were shed. Then cut the filter can, remove the paper element and trim off the end caps, and unfold the media and look for particles. The bushing residue, if you find any, will be non-magnetic, while secondary ferrous wear particles, from say the crankshaft journals, will be magnetic; hopefully you won't find any of those. Lastly, pull a valve cover and see if you find particles hiding in the low spots. This should give you some idea of the extent of contamination and particle sizes.
If you find severe/extensive contamination, say a teaspoon or more of particles and evidence of circulation,, and the engine seems to be generating secondary wear material, a judgement call may be necessary to weigh the risk of more extensive bearing, crank and camshaft damage vs. the cost of an engine refresh. At the minimum, monitoring oil analysis and very importantly frequent filter media checks should be performed. Good luck!
