We have a Toyota V8 hooked up to a 5-speed tranny driving a ball mill. This setup gets whipped like no truck ever does with long runs with constant load changes. We had trouble with some shiny flakes in the tranny fluid. The Magnefine people gave me 2 filters to try out and after 6 months and 2 filters the visible flakes are all gone. The 1st filter was changed after 500 hours and the second was changed at a bit less than 900 hours. There was enough stuff in the first run that the filter got plugged up but the bypass valve worked as advertised and there was no restriction in flow. This is severe service of the worst kind and there is no moving air over the tranny just a big extra cooler. The Magnefine filter did a very good job and it's going on anything I own that need this kind of filtration. So, Magnefine thank you for the filters, it worked well.
