Where is the Neg. clamp....Have one of these but only really needed if you're doing repetitive fastening like replacing a head gasket.
Serious question. Is it backlit, is that what the hot wire is for?Have one of these but only really needed if you're doing repetitive fastening like replacing a head gasket.
You’ve got to hold the dial part from turning, that way the pointer ends up moving with the wrench, and the socket.Serious question. Is it backlit, is that what the hot wire is for?
Calls for 59 lbs then 90 degrees then 60.Just wanted to be as accurate as i can i guess.
Cool. Never seen this style before. TIL.You’ve got to hold the dial part from turning, that way the pointer ends up moving with the wrench, and the socket.
Mine has a post instead of the clamp, but either way you’ve got to fix the dial so that it doesn’t turn
