Tool kit
Kansas, USA
Anyone carry a tool kit on your scooter/motorcycle? Got caught yesterday when my oil line popped off, it was too slippery to put back on by hand! Today got a Kobalt document bag, regular pair of pliers, crescent wrench and already had a screwdriver from a past incident. This scooter is cursed!
The bag folds up prefect and fits in the front pocket of the Yamaha., only can see it if you know what you're looking for. Not sure what else I should take? Don't see a road side tube repair but maybe I should add some patches. Going to put a small tube of 2 cycle also.
My local tool kit involves foldable torx/allen keys, crescent wrench/10-12-13mm wrench's, electrical tape and two screwdrivers. When on trips, that adds mini compressor, tire plug kit, mini jumper and wire. Likely missing something.
I carry that plus a spark plug socket, some zip ties, a couple of different size hose clamps, and a little retrieval magnet. And a multi-tool like a Leatherman or Gerber or something similar. And small vice-grips.
I sure do. I ride in very remote areas. Mostly no cell service and 80% of the trails can only be accessed by bike and a capable rider. Couldn’t even tow a bike out of most places.
Tool kit
  • 10mm wrench
  • 12mm wrench
  • 13mm wrench
  • 8mm wrench
  • 6mm wrench
  • Sockets 6,8,10,12,13,14
  • 14mm deep socket for spark plug
  • Screwdriver flat
  • Philips
  • Fuel filter
  • Side cutters
  • 1/2 socket
  • Shift lever
  • 5/16” fuel hose, splice nipple and clamps
  • Stock QD fuel connector
  • Nitrile gloves
  • Axel wrench’s
  • Zip lock bags
  • Fuel bladder
  • Zip ties
  • Crimp connectors
  • Small volt meter
  • T25 torx bit
  • T30 torx bit
  • 1/4” but adaptor
  • Front sprocket nut(17mm) wrench
  • Master link plus a couple links
  • Needle nose vice grips
  • Fuel line QD o ring
  • 1/4 ratchet and extension
  • Fuses
  • Relay
  • Bug spray
  • Flag tape
  • Compass
  • Flash light
  • Spark plug
  • Wiring diagram
  • 7” 180mm knipex plier wrench
  • Hack saw blade
  • Gorilla tape folded up
  • Lighter
  • File
  • Chain breaker
  • Baby wipes
  • Another 1/4 extension
  • Lock tite
  • Shifter bolt
  • Allen keys
  • Flashlight
  • Spare bolts
  • Advil 400mg
  • Combat split
  • Folding saw
  • 4mm hex bit ratchet for fuel injector
  • Fuel injector
  • Emergency blanket
  • Filter straw
  • T45
I also carry some spare parts like a fuel pump, shift lever, etc.
I carry a small packet, multi-screw driver, fold up allenkey set set of pliers. Thats it, the big thing I do carry is a can of "fix a flat" and on longer trips a pocket compressor and maybe some tire plugs.
I also have a Leatherman multi tool, flashlight, tire repair kit, lithium battery pump, lithium battery jump pack. The R1250 GSA panniers are really big. I can fit my Shoei in the left one.
Wow I thought I was doing good with what I got 🤣 Granted this is a 80cc scooter. If and when I get a motorcycle a lot of good ideas on this thread!
My RC45's tank bag contents: Total weight 2 pounds 5 oz
1 Home made aluminum chain adjuster spanner
2 & 3 BMW tire repair kit
4 tape measure
5 fuses
6 pen
7 flashlite
8 razor
9 digital infrared thermometer for tracking tire temps
10 digital air pressure gauge
11 Rolaids (CHP gives me heartburn)
12 Brown Bomber (Advil)
13 home made tool to access tail cowl storage space
14 5mm allen... spare mirror screw... cross point tool...
15 525 master link...
16 Home made collapsible lift to levitate the rear tire in order to lube chain every tank full
of gas...
My home made tank bag platform...
I carry everything I need in a Modified Chase Harper tank bag...
I've carried a tool kit on my bikes for years. I rarely ever used it. Just a couple of common sized wrenches, a changeable tipped screwdriver with duct tape wrapped around the shank, and a adjustable wrench to fit what I think might loosen up. If something breaks or falls off, all the tools in the world ain't gonna fix it if duct tape doesn't work. I'd rather have the space, and less weight haul around.,,
When I get an old bike (the only kind, for me) the first thing I do is reconstitute the OEM tool bag, which is always missing its pliers, the 10mm wrench, and maybe some other random tools. Then, as I add farkles, if there's a fastener in them (Torx, obsolete crap like SAE fractional, a metric hex size not already present, etc.) I add them to the tool bag, or a small tool wrap if necessary.
On the big cruiser I go far and have big bags, so I also have a Safety Seal kit with small and large ropes and a little inflator with SAE battery connector. The little twin has tubes, so for tire care it just gets a pencil type air guage in the OEM tool bag.
