Originally Posted By: sciphi
This begs the question of how similar are the so-called 'Dex-clones' to real Dex, and will they exhibit the same problems?
According to the MSDS sheets I've looked at, Dexcool's OAT additive is potassium 2-ethylhexanoate.
All of the "all makes" coolants that I've looked up (including Prestone and a few others that I don't remember) use sodium 2-ethylhexanoate.
My chemistry background is a single semester of college chemistry... so I may be talking out my a$$ here. But I know that sodium and potassium are chemically very similar, and pretty much interchangeable in ionic compounds (both are a +1 ion in an aqueous solution).
So while there is a slight chemical difference between Dexcool and assorted "all-makes" coolant... they are very very similar. And both contain the OAT additive 2EHA that is commonly blamed for Dexcool's gasket-dissolving properties.
IMO, they're essentially the same thing.
Chris142- seeings how you work at a radiator shop: Have you seen customers running "all-makes" coolant come up with anything similar to Dex-sludge?
