JHZR2
Staff member
Hi,
I put Delvac 1 into my 83 MB 300D turbodiesel about 3300 mi ago. It has since been taken on a 1000 mile road trip, and a bunch of shorter (100-300mi) road trips. Mostly all highway or moderate speed milage.
I changed the filter and toped the oil off at around 2000 mi.
When I check the oil, it is really thick, just kind of sits on the dipstick. The 10w-40 I have in my BMW drips off the dipstick and isnt as thick in the same temperature as the 5w-40 delvac 1. Is this a sign that either the oil has taken on too much soot, or has cleaned a lot of the engine and has a lot of junk in it?
I know it is very cold for any oil (always hovers a bit beloiw freezing), so it will be thick, but I dont think it should be thicker than the heavier synth in my gas engine...
I have two more gallons of it, and will drain if needed, but I was kind of hoping to keep it in for 5k mi. But Ill drain if needs be. I will do an analysis next time (this time there was still rotella in the system)
Thanks
JMH
Thanks
JMH
