Originally Posted By: Gokhan
Wear at idle has nothing to do with oil pressure. There are no pressure-lubricated (hydrostatic-lubricated) parts in the engine. Oil pressure has no effect on wear -- it merely helps to circulate the oil. Wear at idle results from low RPM, not low oil pressure, as lower RPM decreases the oil-film thickness.
For example, when the engine stops, bearings and crankshaft make contact. This is not because of lack of oil pressure -- it's because of lack of RPM. Increasing RPM decreases the wobbling of the crankshaft in the bearings and increases the oil-film thickness. This applies to other parts of the engine as well.
Another good and goes totally against the wisdom constantly repeated here that using a thinner oil then specified by the manufacturer will reduce wear on cold starts.
