Well, this has nothing to do with the original thread, but for the past 2 days I've been trying to fix this inconsistency I mentioned earlier.
I replaced the coolant temp sensor and still the gauge sits at 155 degrees. I checked operation of the gauge by shorting the connection, goes full up - good, I checked the ground of the sensor, good, the ohms at 195 degrees is 255 which seems correct, the voltage to the sensor is correct. All signs point to the gauge itself being the culprit, so tomorrow the cluster is coming out to be checked out.
