No - not cold pressed rattlesnakes.
May I suggest trying some of a material called Inorganic Fullerene like WS2 (Tungsten Disulphide). There are threads here in the additives category. The one about WS2 the ultimate lube has the most information. Most of the things the naysayers felt the need to provide are in there as well.
You can now get the material from the Oil Hub. The draw back of their specific product from APnano is that is suspended in some non-synthetic motor oil. It is a concentrate.
It behaves similar to MoS2, but it is harder, slipperier, takes higher temperatures, and is better at permanently bonding to surfaces.
I am going to use it on guns and engines. I have been trying to find some for a long time. I have some larger particle (around 600nm) regular WS2 that I put in alcohol to apply it. For the APnano IF WS2 I will lubricate it with the concentrate and later (after firing the gun) flush the oil carrier residue.
One area of concern is it may permanently change the color of metals that it is applied to. I am not sure yet. The IF WS2 can be burnished onto a surface (just about any material) and it will form a semi-permanent coating. I just have not seen the results after firing yet. It is tenacious black stuff so be careful what you get it on.
You can also use it to coat bullets, but you should use the non-IF WS2 powder for that. Note that it will coat the barrel and will increase the speed of bullets through the barrel. This can lead to needing an increase in powder charge if you are loading. The bullet can speed up enough to shorten the acceleration period.
There is some anti-oxidant effect; but not a primary feature. It may also reduce fowling. I have not experimented to any extent at this point. I don't get out to shoot a lot so I would be real interested in hearing about results from anyone else that experiments with the material.
