Delete.
Solar and wind powered. lolI am sure they will have charging stations on the battle field...
They built a large solar array that provided enough electricity to save the base $1M a year over commercial sources.
The life of this array was projected out to 20 years. The land it uses is provided at no cost. The taxpayer cost for the array was $100M.
But wait, it fits the current narrative so why not? lolAnd there ya go. Spend $100 million to save $20 million. No wonder the country is broke.
So, the US Military is ordered to go electric. I believe that is absolutely ludricious. Here is an example: an average EV weighs around 5000 pounds and has a 1000 pound battery. So that is around 20% of it's weight. It can be recharged on a 230V AC charger, in your garage in lets say 6 hours.
An M1 tank weighs around 120,000 pounds. That's 24 times the weight of the average EV. It would need a battery that weights 24,000 pounds. So, your garage charger would recharge it in 24 X 6 = 144 Hours. That is 6 days.
Now, suppose the Army devotes a diesel generator that has enough power to run 6 garage type chargers. That would only take 1 day to charge up your tank. Of course, now the army has to deploy a diesel generator, diesel fuel, and maintainance people and parts to maintain it. It still has to deploy the tank. The only "green" involved in this boondoggle is money. The same problem for troop carriers, heaters for tents, etc. etc. etc.
Of course, there are some that say: We will use only green energy to recharge our vehicles. Well, lots of luck setting up windmills and sun powered farms in a combat zone. I guess we will only attend a war if the battle zone is already equipped with green electric chargers. I wonder where that battle field will be?
I am grateful to be a Retired Air Force MSGt.
Fully electric makes little to no sense.
Hybrids do, especially considering all the waiting and watching armored crews do.
The hybrid Abrams is pretty awesome zero heat signature when hanging out to give away your position.
I suppose it might be better in a sea of noise. I was thinking more of direct infrared targeting, where it's more infrared optical than anything else. I remember hearing claims that somehow the DoD would have a hard time hitting that Chinese spy balloon with a missile, when it seemed to be pretty easy. There were all the claims that it didn't have a heat source, but everything I heard about modern infrared targeting is that it's just a camera that's homing on features of an image like we might see in a night vision camera.
Correct, at least with the Javelin, not sure about other IR weapons. The target is essentially a picture so a picture get taken when the operator "locks on" a target and then the missile will refresh itself X amount of times per second while flying.
Completely and utterly nonsensical.
Folks, it's time we stand up for what's real, possible and practical, and what's not.
So coal and gas powered buses, or do we move operations to night, and have them charge while the sun shines ?This is getting kind of silly. The DoD is looking into hybrid propulsion for some combat vehicles, but they're really looking at going all electric as much as they can for all that mundane transport they do. I mentioned it before - passenger cars, pickups, buses, cargo vans, etc. Like getting a Big Mac at the base McDonald's. Buses are uniquely suited for transit buses because there's typically a large unused space that can then be configured for batteries and they don't typically have cargo holds. Even with cargo holds there should be ample space for batteries with a high floor bus.
The technology for this already there. I see a lot of EV passenger cars and SUVs in my neighborhood. I've ridden on all electric transit buses. The challenge would be in charging infrastructure.
We have to get with the program. Charge them off peak, and save money. lolSo coal and gas powered buses, or do we move operations to night, and have them charge while the sun shines ?
I was thinking of the Sidewinder. The balloon shot over the waters off of South Carolina was apparently shot with an AIM-9X, which has an infrared imaging seeker. Raytheon makes the Sidewinder and the Javelin, so it wouldn't surprise me if they have the same people working on both.
My reading of the Javelin is that it does its seeking based on temperature differences in an infrared image of the target, which would be easy with something like the edge of a tank. It could probably hit a stationary target that's cold, just based on easily seen temperature gradients.
I've heard that the Javelin has been used to hit helicopters and even buildings. A building would definitely look like something with heat differences. I guess it could just lock on the chimney.
This is what the Jav IR system sees in white-hot mode (pic found on Quora but it's the same in training docs.) Personally, I like black-hot more but it's all circumstantial.
A target reticle gets manually placed into position around the target, sent to the warhead and as the warhead flies it will update the picture in-flight. You are correct, it can also be used against hovering/slow helicopters and buildings, which what it's primary use in the Middle East. Only 2 are allowed per USMC battalions for training and all use of it in Iraq/Afghan had to be approved by the Battalion CO first.
It's a lot harder than it seems but the optics on the system is astounding. The IR isn't for the missile's targeting per se, it's for the operator to easily see concealed vehicles and crop a picture of it so the missile can follow the picture.
I suppose the first thing people are thinking of with any kind of anti-tank missile is that it's going straight at the target. But I guess tanks are far more vulnerable from above. I found some video. It's probably an older version, but it clearly shows the missile going high up. You can't see it very well, but it's obviously dropping almost straight down on the target. I heard that's how a Phoenix missile worked - going well above the target and then dropping down.
Yes, top-down shot to vehicles, direct fire to helos, buildings, and vehicles that is under cover/concealment. I'm not aware of any direct-fire munitions that are IR except the Jav, at least ones that can be used by infantry and ground vehicles. All the direct-fire ones I know of are non-guided rockets like the LAW/SMAW or wire-guided like the TOW.
Yeah - standing there watching a wire guided missile seemed rather dangerous, although I'm thinking that it might make more sense to use cameras. But raining fire from above seems almost insanely brilliant.
