TGMO 0W-20 SN, Toyota Highlander, 11400Km
Russia
my last OCI was on Toyota 0W-20, plastic can, made in Sweden.
Engine 3,5L, 2GR-FE, gasoline.
I use only TGMO in plastic cans, Mobil inside, no Japanese mid SAPS oils)))
I tried to use all avalable different TGMO's in Russia.
Big number of Cu, Si, Fe in first OCI's are due to new engine.
Factory fill and 0-20 TGMO are mid SAPS oils, all others are full SAPS with initial TBN around 10-11.
So one engine, same conditions, one driver))) Please comment!
Quote:
Oil_______FF oil 5W-30_____TGMO 5W-40 SM_____LUKOIL LUXE 5W-40 SN_____TGMO 0W30 SL/CF_____TGMO 0W-20
Km on oil___8 000_______________9 600_______________10 600_______________9 000_________________11 400
Km on Unit__8 000______________19 700_______________30 200______________39 200________________50 600
KV100_____9,03_________________11,86________________11,78_______________10,1_________________7,91
KV40______58,6_________________72,34________________69,27_______________55,72________________38,99
VI________132__________________160__________________167_________________171__________________180
Ca________2222_________________2352_________________2571________________3044_________________2272
Mg________13___________________12___________________18__________________11___________________11
Zn________1022_________________913__________________1173________________996__________________812
P_________876__________________752__________________983_________________884__________________730
B_________0____________________160__________________43__________________10___________________3
Mo________87___________________0____________________4___________________0____________________90
Sn________0____________________0____________________0___________________0____________________0
Pb________1____________________1____________________0___________________0____________________0
Cu________332__________________98___________________9___________________7____________________3
Fe________45___________________5*___________________20__________________16___________________11
Cr________1____________________0____________________0___________________1____________________0
Al________21___________________7____________________4___________________8____________________4
Si________243__________________65___________________25__________________19___________________16
Na________1____________________6____________________3___________________2____________________3
K_________0____________________1____________________0___________________1____________________1
TBN_______3,51_________________5,02_________________5,24________________5,38_________________3,27
TAN_______2,69_________________3,57_________________3,3_________________3,86_________________2,65
*- lab mistake IMHO
Originally Posted By: buster
Interesting, so did it lose that much of it's VI from being in service?
If it was made here maybe it lost it during shipping! lol
Would be interesting to see a VOA of the Russian brew, if it did in fact start at 200+ so much for the "new and improved" VMs!
Other than that it looks like the engine is doing well.
If I'm not mistaken he took a VOA and it was 219. It dropped significantly.
Great to see someone else paying for KV40 measurement in UOA. There's a dearth of information on how these high-VI oils maintain that property with use.
TBN looks reasonably strong for the mileage.
What lab is this?
This is lab of one of the Russian lubricants producers. So this lab can test more parameters than "conventional monitoring" lab.
yes, I see that I can run on fullSAPS oils 15-20 000 Km at the same driving conditions. but my car is new one and Toyota service rules require to do service works each 10 000 Km to keep garantee in Russia.
I think that characterization is a little harsh. It's still a 180 VI with a 7% kinematic viscosity loss @ 100C and the lower VI prior fill is part of that. That's still a higher VI than any virgin OTC 0W-20 and those oils often have a drop in VI as they shear and they often shear more.
Just take a look at the 5W-30 FF with only a 132 VI. It's virgin VI was likely in the 160 range.
When an oil shears for the VI to decline, and it usually does somewhat, the KV100 measure must drop at a greater rate than the KV40 but the KV40 still does decline otherwise the oil would get noticeably thicker on start-up even at room temperature.
And in all the oils I've used I've never observed that; i.e., an oil pressure rises on start-up as the oil ages doesn't happen.
In this particular case the TGMO 0W-20 KV40 is higher than the virgin oil and it is due to the much higher KV40 of the 30wt prior fill.
But I agree I wish more members chose to include a KV40 test, their is little point in buying a high VI oil if it's not largely retained in service. Some GP III 5W-50's don't perform particularly well is this area.
Interesting that the FF and the 0w20 are the only ones with any (trinuclear) moly in them.
Looks like an excellent trend you've got. Would love to see you do one type of oil for three changes in a row. Keep it up!
Now I am on Castrol Professional E 5w-20 with Ford 948B. But in future it will be possible)))
