So I got my first "baseline" UOA for future trending comparisons. Here's the background:
1. Stock 2010 G37 Sedan 7AT (VQ37)
2. Oil change at 400 miles to Pennzoil Yellow Bottle 5W-30 with PureOne filter
3. Oil change at 1400 miles to Castrol Syntec Blend 5W-30 with PureOne filter
4. Sample taken at 2800 miles on unit, 1400 miles on oil
5. 100% city/short trip driving on Sample, sometimes at freeway speeds. I drive about 14 miles a day on average (the Sample was in the engine 100 days).
6. Shell VPower gasoline with additives such as LX-2300, FPC and DSFM.
7. FilterMag in use.
Analysis by Dyson/MRT
V40C = 51.8
V100C = 9.2
Visc Indx = 162
(Sheared to 20W. Will no longer be using Syntec Blend)
TBN = 4.4
TAN = 2.39
Flash = 380
Fuel = 0.568
Oxid = 12
Nit = 7
(Excellent combustion efficiency with Nitration at 7 and Fuels dilution at 0.568 - can the rings be sealed already??? I hope I can keep Nit/Fuels at those levels)
Soot = 0
(PureOne doing its job)
Glycol = 0.12
(Apparently Castrol uses some Glycol in their oil)
Additive Metals
Calcium = 2107
Magnesium = 9
Zinc = 917
Phosph = 743
Moly = 27
Barium = 0
Antimony = 0
Boron = 17
Contaminent Metals
Silicon = 48
Sodium = 83
Pot = 3
Vanad = 0
(The silicon is high. But I have seen much higher silicon readings on UOAs from fresh G37 engines. I expect this to trend down through break in).
Wear Metals
Iron = 18
Copper = 72
Lead = 5
Chrom = 0
Alum = 7
Tin = 0
Nickel = 0
Titan = 0
Silver = 0
(Pretty pleased here. All of the wear metals are at or near "Universal Averages" already except for Copper. And I have seen much higher copper readings on UOAs from fresh VQ37 engines. Further, I expect Copper, Iron, Lead and Aluminum to trend down through break in).
I will be running EcoPower 10W-30 from ~2.9K to ~6K miles on unit with another PureOne, sampling at ~3K miles on oil.
V40C = 51.8
V100C = 9.2
Visc Indx = 162
TBN = 4.4
TAN = 2.39
Flash = 380
Fuel = 0.568
Oxid = 12
Nit = 7
Soot = 0
Glycol = 0.12
Additive Metals
Calcium = 2107
Magnesium = 9
Zinc = 917
Phosph = 743
Moly = 27
Barium = 0
Antimony = 0
Boron = 17
Contaminent Metals
Silicon = 48
Sodium = 83
Pot = 3
Vanad = 0
Wear Metals
Iron = 18
Copper = 72
Lead = 5
Chrom = 0
Alum = 7
Tin = 0
Nickel = 0
Titan = 0
Silver = 0
