Originally Posted By: willistheguy
Okay okay okay!
Let's refocus here. The reason this post exists is to discuss the reasoning for using a straight weight oil for an engine rebuild. I did not give that much information about my engine build initially because this was supposed to be more of a general topic.
Here are some responses:
-I am not concerned about block/oil heaters because this is not a winter car, I just happened to finish the build near winter.
-You are right CT8, measuring is important. I'm in school for automotive. (I haven't taken my fuels/lubes course yet ). I don't want to get into the discussion of why I did what to my engine. It was calculated. I just want to discuss this threads topic.
-Some would disagree with those of you who are saying you don't need to break in a roller cam: Roller cam break in. Also from Micheal Prodemand's general break in tips (doesn't specify roller or not but roller engine vehicle was entered into prodemands vehicle search): "Breakin procedure is required when new or reground camshaft has been installed. Operate and maintain engine speed between 1500-2500 RPM for approximately 30 minutes. Procedure may vary due to manufacturer's recommendations." (I get break in is much more sensitive for flat tappets but nonetheless some say you need to do the same break in for roller cams)
Since people asked, here is more details on THIS build (I still want to focus on the straight weight oil question)
91 thunderbird 302 block, cylinder bores ball honed only
87 mustang rotating assembly + pistons
new cam bearings, rod bearings, main bearings
chrome moly piston rings (would switch to iron if I could go back)
96 explorer heads/intakes with full valve job and new springs
Trick flow stage 1 roller cam
Ford racing lifters + new pushrods
1.6 Roller rockers
Reman oil pump
Comp cams timing gear set
Chrome moly rings are the way to go.
Okay okay okay!
1.6 Roller rockers
Reman oil pump
