Originally Posted By: yeehaw1960
The problem with the little two stroke or four stroke "cultivators" is that people go out to the unbroken ground in their back yard and try to use them like a tiller. They work them to death trying to till ground that's never been worked. I have a two year old Honda out in the garage now that was worked by one of my customers until it died for good. The good news was that it only cost him $300 plus dollars to till two new small gardens. Buy a cultivator to maintain, weed, and mix fertizler, peat, or manure into your garden. Rent a real tiller to initially break ground. Grump and Growl.
Agreed. I am using a 14" drain spade to turn the soil first. We bought the house last November I am pretty sure the earth has never been worked since the house was built in 1985. But once you turn it over the MM-55 is more than capable of giving you very nice soil.
It works very well as a dethatcher with the optional kit. The issue I had with the Mantis trying to dethatch was being rear drive it planted it's self down into the ground too much and was a pain to drag across the sod. With the MM-55 being front drive and the weight down on the wheels you just rev up the engine and slowly pull it back across the sod.
Don't waste your time trying to use it as a string trimmer, otherwise it is a great machine.
Also regarding the gearbox. It has no place to fill with fresh grease. It comes apart with six or so screws though and I just cleaned out all the old grease with paper towels and spooned in gobs of Shell Gadus red lithium grease. As long as a bit comes out all around the gearbox when you put it together it should be okay.
Obligatory picture of my machine as I use it today.
