Seems my stability control has been kicking in too much since this, maybe a coincidence. Did you experience this at all? I tried a zero point calibration but no change.Had them installed on an 01 Tundra for over a decade now. Been loving the sharp steering response.
It also "cleans" up toe-in alignment specs since it prevents steering rack side-to-side movement.
Stability control can be triggered by a misaligned front end.Seems my stability control has been kicking in too much since this, maybe a coincidence. Did you experience this at all? I tried a zero point calibration but no change.
You lose ABS function this way? Would be tough to do that here since it’s our family hauler and it rains a lot. I’m thinking of having the alignment checked for starters. Not sure that will help any though.The yaw sensors are a known to get wonky on these, and the modules themselves can get intermittent as well. The VSC and ABS on my Sequoia started going off at random times and got to the point I just disconnected the fluid sensor connection on the master cylinder to shut the system down so I could even drive it. I plan on digging into it once life settles down and I get a day or two to mess with it, but the whole VSC system on the 1st gen Sequoias and Tundras is a half-baked buggy mess of stupid even when its working correctly, and even worse once things go awry.
Oh really? That’s good to know. Thanks! The stability thing is bugging me but the ABS I want to keep at least. I want to just have it work properly though. Is there a particular plug to disconnect?Its shuts off the stability control and traction control but the ABS stays active.
