I'd like to see if someone can figure this out. If you can figure this out(unless it is the engine temperature sensor)then you are the god of mechanics.
I have been trying to diagnose this problem and I can't for the life of me figure out what it may be. I have a list of components that I could look into but it would take forever.
(('93 cavalier 2.2 160k))
Here is the problem. When I start my engine up(cold)it won't start. Try it again and it will shudder very very badly. It's as if the car
is choking on a piece of chicken bone. At this point the whole car is shaking very erradically. I turn off the car...start the car again and
it's a little smoother...but I have to push on the gas to clear up the rough idling. The car feels fine after that.
My vacuum lines are fine, my egr valve is fine, my rotor seem fine(no rough driving on the road), my fuel pump is fine, my engine temperature sensor seems fine, MAP sensor looks fine, uhhh....I think there are a few more I can think of...
I also changed my gasoline brand(was using chevron...now I'm using shell)and used octane 93 with bg44k. After 2 more tank fills of just the octane 93 from shell.....no improvement!nothing.
I had such a strong gut feeling that this may be caused by a engine temperature sensor(TCC). I checked the ohms on it and got the following:
cold engine = .874
hot engine = .341
now my only thing is ... is that the manual states that the ohm reading - when the engine is hot - should be equal or greater then 500 ohms ... to that of the cold engine. Well, I have the opposite effect. Yet I do have the 500 difference. To double triple check I took out the sensor to look for corrosion and I only saw a little bit. I took a wire brush and cleaned it up real good. Stuck it in and waited till the engine had really cooled off. Turned the car on....no improvement.
One time I even left the sensor unplugged while driving(forgot to plug it back in) and I didn't notice any performance issues.
so...AHHhhhhhhh!! What the "blank" is going on here?!
oh wait. One more thing before I stop here. I did clean out my throttle body(the butterfly) with gumout. It seems that ever since I did that... this problem seemed to have creeped up. Now this could be a coincidence....
-jer
cold engine = .874
hot engine = .341
-jer
