- Joined
- May 24, 2023
- Messages
- 130
lolConspiracy theories about the ID of the poster.
Make him show his papers!In before everything that is coming including but not limited to:
Bickering.
Heads blowing off.
Lock.
Etc.
Adding to this. I live in south west Pennsylvania and the temperature swings from -20 to 105 degrees FI do basically what the op implies. I run mobil euro 0w40 in everything(3.6 pentastar, 2.7 ecoboost, 5.7 sbc, 5.0sbc, 5.3ls, all the ope) except my 12v cummins
It's cheap in the 12qt boxes at wally. I keep 3 on hand
Still insufficient for high performance applications.Mobil 1 (1975) had HTHS about 2.6-2.8 cP..
listen, I just want to make it clear that I wasn't the one recommending this. (C.P. Gilmore did) Take a moment to revisit "the picture" and see for yourself. It'll give you a good chuckle!Still insufficient for high performance applications.
Yeah it’s funny.listen, I just want to make it clear that I wasn't the one recommending this. (C.P. Gilmore did) Take a moment to revisit "the picture" and see for yourself. It'll give you a good chuckle!
It's a BITOG classic!
But it IS a matter of the base oil type, that's why carrier oils are used for the additive package because PAO and Group III, regardless of the viscosity, have poor solvency. Pointing out that Yubase 4 has better solvency than Yubase 8 is like pointing out that .223 has lower penetration than 5.56mm, ignoring the fact that the difference is so minute that it's immaterial. They both suck.It's not merely a matter of the base oil type; the crucial factor lies in the viscosity itself. In the case of 0W-20, both the amount of PAO and, more significantly, the viscosity are reduced. As viscosity increases, the capacity for effective dissolution diminishes.
They all suck, all the PAO's, it doesn't matter which one you are looking at, hyper-focusing on the aniline point and ignoring this fact is bordering on trolling. That's why oils leveraging PAO as the primary base will use AN's and or Esters to not only deal with the seal shrink issue, but also add sufficiency solvency.This fact can be easily verified by consulting the documentation on the aniline point of any base oil. While PAO4 may still exhibit some dissolving capabilities, PAO8 falls short in comparison. PAO6 typically resides at the border, representing a transitional variant.
Again, Group III solvency is extremely poor, this is why carrier oils are used, to provide sufficiency solvency for the additive package and sometimes we STILL see settling out in the finished product, like with certain Shell products. This is also why your typical ILSAC oils, blended to a price point, are not good at cleaning. You need something highly polar, or with good solvency (esters or AN's) to actually solve deposits.Similar principles apply to group III base oils, albeit with an initial advantage in terms of dissolving power (owing to a higher presence of naphthenes in III). However, for 0W-20 oil, a less viscous base and a reduced amount of polymers are employed, ensuring optimal performance.
Machinery Lubrication said:As the base stocks change, additive selection must change accordingly. For example, the same antioxidant package critical in a Group I petroleum lubricant formulation will not remain soluble in the new Group III base stocks produced today.
From what I recall, it was more around the 3.0cP or higher mark, more similar to the HTHS for HPL's current Euro "No-VII" 5W-20, which has an HTHS of 3.2cP. I think @Shannow posted a picture or something that showed it at one point.Still insufficient for high performance applications.
It wasn't, somebody dreamed it up.This is sort of tangential to your comment: I am continually amazed at the concoctions folks put together in order to improve or modify a fully formulated oil. How have these concoctions been determined? What's the basis for using, as in this example, a 0W-20 mixed with a thickening agent, like boat mineral 4T-outboard oil, such as 25W-40. How was it determined that this is a good and beneficial choice?
Which is the vast majority of users on the road (NOT high-performance apps).Still insufficient for high performance applications.
There is a huge spectrum of 0W-20's on the market ranging from minimal VII content to considerable VII content and this can be inferred from the VI of the finished product. If you've got two 0W-20 and one has a VI of 160 and the other one 212, you can be certain that the one with the higher VI has considerably higher VII content and lower viscosity base oils. This is very common with the Japanese OE 0W-20's like TGMO.
New cars have warrantees. In the unlikely event of a motor failure-manufacturers have been know to ask for all kinds of documentation. I know of very few NEW vehicles that spec the oil the OP mentioned.Why not indeed.
How can you do that spread without VII? I don't see the big thing with the no-VII oils here. Their 5W40 shoudl be good enough for anyone.If you want one oil to rule them all, we need @High Performance Lubricants to add a 5w40 to their No VII product lineup. You could still get Euro or d1G3 add packs, and have an ideal all-fleet oil for gas and diesels.
The beginning of the "thin oil crusade".listen, I just want to make it clear that I wasn't the one recommending this. (C.P. Gilmore did) Take a moment to revisit "the picture" and see for yourself. It'll give you a good chuckle!
Unfounded claim unless someone has actually tested an old can of 1975 Mobil 1 oil. SAE J300 didn't even define the HTHS spec for motor oil until the Feb 1992 version of SAE J300.Mobil 1 (1975) had HTHS about 2.6-2.8 cP..
But they are still poor, as CLEARLY illustrated in the graph provided. Having the least stinky crap in the outhouse doesn't make it any less crap. You can dress it up, but Group III still has relatively poor solubility compared to other bases. Yes, PAO is worse, as noted, but they are both bad.To be perfectly accurate, this claim holds some inaccuracies. When we compare the aniline points of group III and PAO base oils, an interesting trend emerges. Due to the elevated naphthene content in group III oils, their aniline points tend to be consistently 5-10 degrees Celsius lower (at the same comparable viscosities), indicating superior solubility characteristics. It's important to note that the aniline point consistently decreases (goes better) within a particular series of substances as viscosity decreases.
I've provided blending examples of both, I can provide more if you like? The 0W-20 was primarily blended with 4cSt Group III, with one of them using some 6cSt (and 1% less VII), the 0W-40 was primarily blended with 4cSt PAO and 4cSt Group III. Even the all-PAO 0W-40 from Mobil's blending guide uses no 8cSt bases, being 34.1% PAO4, 40% PAO6 and 2% Esterex NP343.In the case of 0W-20 oil, the primary base utilized generally possesses a viscosity KV100 of 4, occasionally reaching 6. Conversely, in the context of 0W-40 oil, a predominance of base oils with viscosities of 6, and occasionally 8, can be observed.
Do you have any examples of this? I'm not discounting it, but would like to see some proof. That might explain Shell having some additive precipitation issues with some of their products.In real-world scenarios, it's fascinating to note that some manufacturers actually choose to utilize group III base oils as carrier oils.
You mean like this?What's even more intriguing is that they tend to lean towards oils with a substantial presence of naphthenes, usually 20% or more. These observations from practical experience shed light on the diverse approaches within the industry.
These oils seem to be primarily produced by/for Asian OEM's, TGMO is probably the best known/most discussed example on here, but there are others. And yes, they are generally lower availability in the US market.In formulations where the viscosity index of 0W-20 oil surpasses 200, a special type of polymer called methacrylate takes the stage. This polymer shares a structural resemblance with esters and possesses remarkable solubility, all without burdening the solution like the mechanically stable polymers found in 0W-40 oils. While a generous amount of this particular polymer may be incorporated, it belongs to a different breed that maintains the solubility of base oils, setting it apart from its counterparts in 0W-40 formulations.
In the current American market, oils containing methacrylates for 0W-20 applications are relatively rare to come by.
"Average" and "Generally" are doing a lot of work hereGenerally, 0W-20 oils that adhere to ILSAC specifications tend to prioritize other factors over mechanical polymer-resilience, resulting in a higher thickening power, particularly when compared to European formulations within the 0W-40 range. The demand for more mechanically stable polymers (ASTM D7109 test) becomes more pronounced in 0W-40 oils, on average, this doubles the amount of polymer in "average 0W-40". This discrepancy can be attributed to the lower requirements set forth by ILSAC and the inherent ability of simpler OCP polymers to thicken more effectively. Additionally, market trends reveal an average viscosity index that aligns with these observations.
Rest assured, the situation is not as daunting as it may seem. In fact, unopened cans of 5W-20 M1 can still be found, offering reassurance regarding the availability of such HTHS probes even today. It's fascinating to note that the first HTHS metering devices were already in development between 1981 and 1983. On a related note, I highly recommend immersing yourself in the pages of James A. Spearot's exceptional book, which delves into the captivating history of High-Temperature High-Shear (HTHS).Unfounded claim unless someone has actually tested an old can of 1975 Mobil 1 oil. SAE J300 didn't even define the HTHS spec for motor oil until the Feb 1992 version of SAE J300.
Yes, as I mentioned above, an old can of Mobil 1 5W-20 from 1975 would have to be tested for KV100 and HTHS. Until then, nobody knows what it was, because it was never published since HTHS specs didn't exist in 1975. Post up the official test data on that 1975 oil, when we'll know.Rest assured, the situation is not as daunting as it may seem. In fact, they (unopened cans with 5W-20 M1) can still be found, providing a sense of reassurance of such HTHS probe even now
