Originally Posted By: MolaKule
I think what Ed said was very telling.
I agree, because it sounds like Ed has actually done just the slightest bit of testing on this.
The suspended or colloidal versions of powdered moly additives do settle out and conglomerate.
Says who? Molakule? Not according to a
'White Paper' on BITOG:
Originally Posted By: BITOG White Paper, page 1
Engineers and scientists have tried for years to use Moly in motor oils but they had been unsuccessful because they could not find a way to keep Moly in suspension. Once Moly was put into suspension it would gradually settle out. It was easy to see it come out of suspension because a black sludge would collect on the bottom of the oil containers. In engines it would settle to the bottom of the crankcase or clog oil pathways and filters.
Engineers have overcome these obstacles. They have developed a process that keeps Moly in suspension and isn't filtered out. Since that time the product has undergone extensive independent testing in labs and in the field for many years to insure that the product stands up to the rigorous needs of today's engines.
Maybe that's the kind of MoS2 that Volkswagen/Dow-Corning is selling? Or maybe Liqui-Moly GmbH? Engineers appear to have overcome these obstacles back in the 1950's and 1960's. They even received patent protection for their efforts!
But, without facts and without a shred of data to the contrary and without lifting a finger to actually test something, maybe I, Molakule, can cast just a little doubt on this, because I am fundamentally opposed to all additives, except those additives that I like:
So when you add a Moly additive, how do you know what are you getting, the colloidal version (suspended particles of powder) or the soluble version? And how do you know how much should be added unless you have done extensive and expensive tests?
How do we know? How could we possibly know? Well, we could trust the
engineers at Volkswagen or Dow-Corning. They sound like solid folks, engineers who actually test before they talk. And they get patents rewarded for their efforts. Or, we could trust the engineers at Liqui-Moly GmbH. They even test in German! And their patents are issued in German!
"How much should be added... unless you've done extensive and expensive tests"... or unless you've read the label. Both VW/Dow-Corning and Liqui-Moly GmbH provide dosage information right on the package. Molykote: "This tube contains the recommended amount for a 5-quart crankcase". L-M MoS2 Anti Friction: "Add to the engine oil at the rate of 3 - 5%"
"How do you know what are you getting..." Well, maybe because it says right on the package:
Liqui-Moly MoS2 Anti-Friction. That was simple.
The folks at VW/Dow-Corning are going to make you work a bit. As if there were any real question, here's a nice Brazilian ad for Molykote which spells out that it's MoS2.
And another...
It looks like the engineers solved this problem at least...
60 years ago!
BTW, does anyone even know of a consumer source of MoDTC or any other form of Molybdenum (other than MoS2)? You sure can't buy it on eBay or Amazon.
