I haven't been able to figure out how to post the actual report so I'm just typing it in. I forgot to mention to Blackstone that I used 1/2 qt of Pennzoil YB to make up the full 6.5 qts.
Comments: We recommend taking a sample in mid-stream, because if you wait until the end, you might run out of oil(I had forgotten to have the sample bottle handy, so the sample came from the last of the drain). But we had plenty so the sampling technique was fine. All wear looks about the same in this sample, which is great considering you ran this oil more miles than the last. The only thing that was out of line was silicon. Silicon can have several sources in an engine, though we don't think it's dirt in your case because wear looks so good. It's probably from a sealer or lube. No moisture or fuel was present in this sample, and the air and oil filters are working.
Mi on oil: 9710
Mi on unit: 62805
Sample Date: 08/23/2010
Make Up Oil Added: 0
Aluminum: 3
Chromium: 0
Iron: 16
Copper: 4
Lead: 0
Tin: 0
Molybdenum: 294
Nickel: 0
Manganese: 1
Silver: 0
Titanium: 0
Potassium: 2
Boron: 14
Silicon: 34
Sodium: 15
Calcium: 1914
Magnesium: 18
Phosphorus: 604
Zinc: 691
Barium: 0
______________________________________________________________
SUS Viscosity@210ºF: 53.2
cST Viscosity@100ºC: 8.24
Flashpoint in ºF: 390
Fuel %: Antifreeze %: 0
Water %: 0
Insolubles %: 0.3
I will be using this oil(Schaeffer's) for 2 more changes, approx 20K mi. Any comments on whether I should buy more of the same or save some $$ on another oil, would be appreciated.
Mi on oil: 9710
Mi on unit: 62805
Aluminum: 3
Chromium: 0
Iron: 16
Copper: 4
Lead: 0
Tin: 0
Molybdenum: 294
Nickel: 0
Manganese: 1
Silver: 0
Titanium: 0
Potassium: 2
Boron: 14
Silicon: 34
Sodium: 15
Calcium: 1914
Magnesium: 18
Phosphorus: 604
Zinc: 691
Barium: 0
Water %: 0
Insolubles %: 0.3
