Originally Posted By: westom
Originally Posted By: Samilcar
This modem adapter that went bad was plugged in to my UPS, so I think it should have been protected.
You might want to view typical power from a 120 volts UPS. When it battery backup mode, this UPS outputs two 200 volts square waves with a spike of up to 270 volts between those square waves. Whereas this power may be harmful to small electric motors and power strip protectors. This power is also perfectly ideal for electronics.
So where is this 'router protection' provided by that UPS. It exists only in hearsay. When not in battery backup mode, the router is connected directly to AC mains. Have any doubts? The post the manufacturer numeric spec numbers that claim all that protection. Where does it list each type of surge and protection from that surge ... in numbers? It does not. A majority has easily been convinced of a myth - that the UPS 'cleans' power or protects that router. Easy to do when the majority ignores spec numbers.
How much variation is acceptable for a router? Incandescent lamps must dim to less than 50% intensity - and that is still perfectly good AC voltage for electronics. Voltage drop that can be harmful to electric motors is well within the normal electronics voltage range.
What causes router damage? That is a topic completely different from what anyone has discussed here. AC power gets blamed for the same reason that witches and extra-terrestrial aliens get blamed. First point - that UPS does nothing to protect the router from anything but a blackout. UPS is installed so that you can continue networking during a blackout - nothing more. Reasons for router failure? A discussion about things nobody (except one) has mentioned.
My UPS is a APC BE750G with the following claimed protection.
Surge energy rating: 365 Joules
Filtering: Full time multi-pole noise filtering : 5% IEEE surge let-through : zero clamping response time : meets UL 1449
Data Line Protection: RJ-45 Modem/Fax/DSL/10-100 Base-T protection,Cable modem / Video protection
Five of the ten outlets are UPS, and the other five are not, but are supposedly still surge protected. I'll admit I'm mostly clueless as to whether or not this is all adequate or not. Are you saying that this surge protection is only in place when the UPS is on battery power? If so, I'm now fairly concerned.
