Originally Posted By: A_Harman
Do you have a reference for the 900ppm P content of RT6?
I have been going by this VOA, which shows 1078ppm: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1939470#Post1939470
(Since it is a Blackstone analysis, I am assuming that their reading is 10-15% low, which would put the P content of RT6 at ~1200ppm.
Similarly, here is a VOA of TDT, which shows 934ppm P. Because Mobil's PDS specifies 1100ppm, and Blackstone is coming up 15% short on P, I tend to believe Mobil instead of Blackstone's analysis.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1939477#Post1939477
Thanks. I now remember that VOA. Certainly 1100 ppm P is pretty strong level of ZDDP, as the CJ-4 maximum limit is 1200 ppm P. It makes Rotella T6 even more attractive.
The UOAs I saw were these and there was another one. There are also this UOA and this one. For some reason P values for Rotella T6 are all over the place, possibly due to the accuracy of Blackstone numbers and also whatever happens to the additives in used oil.
TDT is also probably a very good oil except for lack of moly (perhaps not a problem in modern engines) and some viscosity-shear problems in certain applications (perhaps not a problem in gas engines that can use 5W-30) . I was surprised to see how low ZDDP was in Delvac 1 ESP (assuming the UOA numbers are accurate) and it didn't have moly either, as I was expecting it to be more additive-loaded than TDT. I guess the explicit "ESP" designation makes it more tailored for strict emission-systems protection.
