Changed it back in May with Shell Rotella T 10W-30 and reused the Amsoil oil filter that was on it after draining out the old oil.
Previous fill 5,000 miles of the same oil, see previous UOA here.
Third sample of 5/15/09 was the previous fill of Rotella T 10W-30 and a new Amsoil filter.
Second sample of 7/28/08 was GC with a UPF-52 filter.
First sample of 9/2/07 was Valvoline 10W-30 most likely with a cheap oil filter from my mechanic after fixing some oil leaks.
Napa Gold air filter used, changed at 120k and 130k.
Blackstone Coments:
Aluminum jumped up significantly and this could show a problem developing at pistons. Interestingly, other metals generally read in line with averages. Lead (bearings) increased by 5 ppm, but still reads close enough to average to not be of special concern. The viscosity was higher than spec for a typical 10W/30, reading in the 10W/40 range. We can't tell if this is from excess heat, but no contamination caused it, as no fuel or coolant existed in the oil. The 2.3 TBN shows some active additive left. If the engine runs well, resample in 2-3K miles next fill. Caution!
Comments welcome. If it wasn't for the Aluminum I'd be pretty happy. The Aluminum is scary high. I'm going to do a 2500 mile run and check it again. I did abuse the car severely this run. 2400 miles of this run was towing my 5500 lb travel trailer thru the state of NY which resulted in many miles on long up hills where it was running nearly full throttle for miles at a time. Although we spent quite a bit of time in the Adirondack mountains, one day in particular stands out as we headed west from NY city and it was 90+ degrees. On the long up hills the engine temp. was running around 230 degrees for a sustained period of time. Normally the gauge will run 200-205. I never detected it audibly but perhaps there was some detonation going on eating at the pistons? The car does have an oil to water oil cooler but based on the oil viscosity it would appear to me the oil got hot right along with the engine. Maybe an additional air to oil oil cooler would help here. Perhaps running premium fuel would help as well if there was any detonation?
Code:
OIL RT 10W-30 RT 10W-30 GC 0W-30 Valv. 10W-30
MILES IN USE 5.0k 5.0k 5.6k 4.6k Uni Avg
MILES 130k 125k 118k 108k
SAMPLE TAKEN 8/20/09 5/15/09 7/28/08 9/2/07
ALUMINUM 34 7 6 6 7
CHROMIUM 1 1 1 1 2
IRON 22 26 19 22 37
COPPER 4 3 4 5 11
LEAD 15 10 32 19 13
TIN 0 3 0 0 2
MOLYBDENUM 7 8 7 15 52
NICKEL 1 1 1 1 1
MANGANESE 0 0 1 0 2
SILVER 0 0 0 0 0
TITANIUM 0 0 0 0 0
POTASSIUM 5 4 2 1 9
BORON 19 14 5 7 42
SILICON 18 26 29 94 23
SODIUM 9 7 7 8 26
CALCIUM 2188 1864 1648 1701 1948
MAGNESIUM 49 152 526 66 252
PHOSPHORUS 894 876 868 616 787
ZINC 1189 1076 1054 737 950
BARIUM 0 0 0 2 1
SUS VIS 210ºF 69.7 65.6 66.2 59.3
cSt @ 212ºF 12.88 11.78 11.95 10.02
FLASHPOINT ºF 400 385 385 390
FUEL %
ANTIFREEZE % 0.0 0 0 0
WATER % 0 0 0 0
INSOLUBLES % 0.3 0.4 0.3 0.3
TBN 2.3 2.7 3.6 2.6
Blackstone Coments:
Code:
ALUMINUM 34 7 6 6 7
CHROMIUM 1 1 1 1 2
IRON 22 26 19 22 37
COPPER 4 3 4 5 11
LEAD 15 10 32 19 13
TIN 0 3 0 0 2
NICKEL 1 1 1 1 1
MANGANESE 0 0 1 0 2
SILVER 0 0 0 0 0
TITANIUM 0 0 0 0 0
POTASSIUM 5 4 2 1 9
BORON 19 14 5 7 42
SODIUM 9 7 7 8 26
BARIUM 0 0 0 2 1
FUEL %
WATER % 0 0 0 0
TBN 2.3 2.7 3.6 2.6
