Did I say that?quote:
Originally posted by metroplex:
So Shell Rotella T synthetic wouldn't be that good for engines then - cause it has a higher ash content than other engine oils.
With run-of-the-mill ~10W30 you're right, but it might be a problem. 1/3 0W20 ATF in a BMW that wants 60 is going to be bad if it does more than idle. Different situations deserve their own look.quote:
ATF thins out the oil yes - but its not going to be pi$$ thin to the point its no longer going to lubricate properly. I wouldn't run it for 5000 miles, just maybe around the block or 3-5 miles tops.
One cleaning is ~$.60. I don't know how much shipping or ordering singles would affect it. Cleaning dose is 1oz/qt of oil. Cases of 24 12oz bottles go for ~$34.quote:
How much is Neutra? I usually find the cheapest ATF out there - less than a buck per quart. I almost always have left over quarts in my storage from past ATF changes.
Granted, it's not as convenient if you don't already use it. Give Tim a call? Could be cheap even in singles. (See if he'll break out a gallon - I hate these little bottles.)
David
