I have a BE! power washer of unknown age and unknown hours in the family which was a freebie several years ago. It has a Honda GC160 and a Comet AXD 3020. I believe it would be the 3020 "G" version for 3/4" shaft. Comet says this is 3GPM, 2000psi @ 3400rpm.
It works well but the pump crankcase is experiencing water ingestion and I have to change the pump oil frequently. This unit works well, has cost very little and is probably worth servicing.
I know there are all kinds of pump designs and other considerations made by those more "in the know" than I, but I'd like to pick up some knowledge and, at the same time, not unnecessarily spend money on things I don't need or choose the wrong items.
Based on the fact that it's making good pressue but I have water ingestion I probably need a piston seal kit, right?
I see urls like http://www.shopetsonline.com/Comet-AXD-Series-s/665.htm list common rebuild kits under the pump. I've also looked at http://www.cometpump.com/MB_Pompe.pdf (page 40) from Comet themselves but I find the latter a little overwhelming.
Do I need a piston seal kit? How about the check valves? If it's making pressure I don't need those yet? How about the unloader, should this be serviced? Where are the best places to order that are located in Canada or ship to Canada without a lot of hassle? Anything else I should service while I'm in there? I've seen piston seal kits, "overhaul" kits, "maintenance" kits....what's what? (for instance, page 2 of http://www.deindustrial.com/v/vspfiles/V4_Backup/Comet-AXD-Series.pdf
Thanks!
Thanks!
