Red Line Service Chemicals
NJ
Looks new to me unless I missed it?
I suspect this has more to do with P66.
Quickly removes more engine sludge, varnish & deposits
  • One of the best and most effective ways to clean lubricated engine surfaces
  • Formulated for use in GDI, MPFI, Hybrid and Diesel engines
  • Removes harmful contaminants such as sludge, gum, varnish, and other contaminants
  • Helps restore optimal engine performance
  • Prepares engine for new motor oil
  • Not recommended for first-time use in vehicles with an odometer reading exceeding 100,000 miles
Ethylene Glycol Monobutyl Ether per the MSDS appears to be some sort of cleaner/solvent.
On an aside it looks like RL is turning into a chimera of Liqui Moly with Slick 50.
Engine Protectant with PTFE​
Provides unsurpassed protection above and beyond conventional and synthetic blend motor oils
Helps protect engines from metal to metal wear and friction
RED LINE® ENGINE PROTECTANT WITH PTFE helps protect against and reduce the long-term damaging effects that can be caused by metal to metal friction. Use 1 quart of RED LINE ENGINE PROTECTANT WITH PTFE per 4-6 quart oil change.
These products appear to be aimed at professional service places. Heavily influenced by P66 I imagine. A way to spread Red Line's name.
