Mr. Navone, welcome to the group.
Just a suggestion, but I would have additional oil analysis done by other companies, since my experience has taught me to use two or more oil analysis firms for
important analysis. I suggest Terry Dyson of Dyson Analysis for the most honest and professional analyses. Never rely on one source alone to develop a major hypothesis.
I notice your firm recommends two oils that have high levels of ZDDP, but these are not the only oils that have good Anti-Wear additives.
Some Notes on ZDDP.
Zinc Dialkyl Dithiophosphates (ZDDP):
Identifications
* CAS Number: 68457-79-4
Synonyms:
* Dithiophosphoric Acid, O,O'-Isobutyl Amyl Ester, Zinc Salt
* Zinc Dialkyl Dithiophosphates (ZDDP)
ZDDP is an ester which is used as an Anti-Wear agent and an Anti-Oxidant agent (a multifunctional additive) in oil additives and is composed of the elements of zinc, phosphorous, and sulfur.
In order to detect ZDDP molecules you need to determine if the Z, P, and S elements are present.
Now, in PCMO's and other lubricants, there may be other additives that contribute to the sulfur, and may produce false readings.
One needs to run an adsorption analysis to really determine if the lubricant contains ZDDP in the presence of P, Z, and S.
One CAN have elements of phosphoruus, zinc, and sulfur present without having any ZDDP in the lubricant whatsoever.
I.E., It is possible to have all three elements, zinc, phosphorous and sulfur, and not have ZDDP present.
Phosphor compounds of mainly esters of phosphorous can provide good AW and EP qualities, and was used in hydraulic fluids as AW and EP agents before ZDDP appeared. When phosphor is combined with sulfur and zinc, a synergistic molecule arises. It is believed that the phosphor contributes to the slippery "molten-glass" effect.
There are zinc compounds of naphthenates and neodecanoates that contain high concentrations of zinc, but both are expensive.
I have yet to see any clean oil analysis with zinc and phos. levels below about 600 ppm or 0.06% by weight, although it is not out of the question to develop an oil without any metallic compounds whatsover; it is simply just not cost effective at this time and until proper and less costly AW additives are found, ZDDP will continue to be used at lower levels with supplementary AW additives such as calcium, boron, copper, molybdenum, and antimony.
Another BITOG Article:
http://theoildrop.server101.com/forums/s...part=3&vc=1
Look here for some good laymen’s info on ZDDP chemistry:
http://en.wikipedia.org/wiki/ZDDP
http://www.elcocorp.com/Elco ZDDP table.
An Article on Spectroscopy of oils:
http://www.practicingoilanalysis.com/article_detail.asp?articleid=477
