Hello everyone,
I drive a 94 Honda Civic with a JDM B18C Type R swap in it for several years now. I did the work myself and it runs quite well. Only issue I've got is it seems to have a noisy "dry start" every time after it's cooled off. The noise stops the instant the motor builds oil pressure. I don't know if it's normal for this type of high compression (11.1:1) & rpm (8500rpm) motor, but I do know I don't like the sound at all.
I change the oil about once or twice a year, and it only gets about 2 to 4 thousand miles between each change. Miles are mostly freeway to and from work cruising @ 75mph/3800rpm. I do have a little street driving with fun sprints here and there, but I'm not that hard on it as I still manage 30-36mpg each tank (Chevron 91 octane). I've always run 5w30 synthetic of one brand or another (Q-horsepower, Mobil-1, Penzoil-Plat), along with Mobil-1 oil filters (tried both M1-104 and M1-110), but the dry-start sound always persists.
The inside of the motor seems quite spotless through the valve cover even though the swap is of unknown mileage (pics below). Doesn't seem to burn any oil between changes either (which I hear is common on these motors). Compression looks nice and even across all 4 cylinders. Plugs look good and clean and are changed once a year (NGK V-power copper). The only visible problem I seem to have with the motor is a bit of oil leaking from the hose ports on the factory PCV catch can. It's barely enough to make one drop on my garage floor in all this time.
Thanks for any help/recommendations you can provide. Don't hesitate to ask any questions if I've failed to include important information.
