Most Subarus have a plug in the trunk area that you can remove to run a hose down to the rear diff. If not - You can get a cheap hand pump that fits on a gear oil bottle. I use the one that is made for a boats lower unit. You get less overflow and mess with the pump.
Make sure the upper (fill and check) plug comes out before you pull the drain one....also check beforehand if your diff uses a gasket. Subaru has a couple different rear diffs - not all are NPT.
