Shel_B
Site Donor 2023
- Joined
- Aug 7, 2020
- Messages
- 5,167
There is a metallic-sounding rattle inside the Camry's exhaust pipe. The rattle is located behind the area where the pipe runs from the engine and before the flex joint. I hope the description of the location is clear enough.
It sounds like a piece of metal may have broken from somewhere inside the system, but I cannot imagine where. The engine runs well and is in very good condition. All the usual parameters have been checked in the course of regular maintenance. Fuel mileage is good, power is smooth, and everything seems to be performing well.
Any thoughts on what this may be? The catalytic converter is right up by the exhaust manifold and I'm thinking something in the converter broke. At some point, I'll look into it, but since the car seems fine and there are no indications of this causing a problem, I'm in no rush to tear apart the exhaust system, especially considering local labor rates.
