Canada is facing an incredible raft of car thefts, mostly in Central- and Eastern Canada. Cars get stolen, put into containers, and shipped to Europe, Africa, and the Middle East, mostly, via the port of Montreal. I'm on the west coast... still an issue, but somewhat less so...
My question: if I wanted to make it impossible to actuate the starter, but not have my radio lose its settings, or the various logic modules lose their "learned" drivability parameters... could I do the following: put a "littelfuse" (they're a mfr) knob-actuated heavy duty "battery disconnect" in-line with a more heavy duty starter feed cable? I'd do the cable size upgrade because I'd route (lengthen, by a whole lot) the cable, placing it into a position, say, at the base of the driver's seat, with the only visible part of the "littelfuse" being say a 1/2" hole in the carpeted floor. The knob for the littelfuse would be removed in order to have this starter-disabling action active.
I suppose I could also do this with a very heavy relay, in order to allow the starter motor to be able to receive "juice" when the normal start/stop button commands it...?
Do any of you folks have comments about this simplistic, "mechanical-in-nature" (potential) philosophy to effect theft protection?
Finally, there surely would have to be a more appropriate under-floorboard (removable) screw-actuated "switch" than the littelfuse... which would necessitate some fabrication on my part to properly mount and (electrically) insulate said component?
