Here is the UOA on my 2007 Acadia within 50 miles of the check engine light coming on. The high fuel is probably because I had to idle the car for Onstar to do diagnostics on the CEL and because I also needed coil pack replaced.
Code:
MI Oil 4,598 UNIT 5,653 4,937 5,483 2,938 UNIV
Unit 43,667 AVGS 39,069 27,666 19,221 13,738 AVGS
Date 03/11 11/10 12/09 04/09 06/08
ALUM 4 4 4 3 6 3 5
CHROM 1 1 1 1 1 0 1
IRON 74 58 43 47 116 12 28
COPPER 4 5 4 5 6 5 15
LEAD 1 1 2 2 1 0 2
TIN 3 2 2 0 2 1 1
MOLY 43 54 46 42 23 118 67
NICKEL 0 1 1 1 1 0 1
MANGAN 3 3 4 2 3 1 3
SILVER 0 0 0 0 0 0 0
POTASS 0 1 0 2 1 0 2
BORON 50 29 49 10 6 28 41
SILICON 24 23 37 24 14 15 15
SODIUM 8 25 1 90 5 4 48
CALCIUM 1704 1799 1920 1983 1976 1412 2178
MAGNES 8 9 9 9 12 6 51
PHOS 592 597 602 627 615 550 670
ZIN5C 761 766 808 771 824 667 828
SUS Viscosity @ 210°F
55.5 56-63 58.7 55.9 55.3 53.4
cST Viscosity @ 100C
8.93 9.1-11. 9.84 9.04 8.86 8.30
Flashpoint in °F
340 >365 385 385 385 350
Fuel % 1.3
Antif% 0.0 0.0 0.0 ? 0.0 0.0
Water % 0.0
Insols% 0.5
TBN 2.2 2.0 2.3
Here are Blackstone's comments on this UOA:
CHRIS: We found an increase in iron in this sample taken at 43,667 total miles. It could be from the timing chain or camshaft issues you're experiencing. Fortunately, the other wear metals look good. This level isn't quite as high as we saw a couple of years ago, but it's still cautionary. The low viscosity is likely due to the
1.3% fuel dilution. The fuel is likely from idling before the sample was taken and it's not a problem. Air and oil filtration were fine. Let us know what you find out at the dealership. Hopefully it's a simple fix.
Code:
ALUM 4 4 4 3 6 3 5
CHROM 1 1 1 1 1 0 1
LEAD 1 1 2 2 1 0 2
TIN 3 2 2 0 2 1 1
Flashpoint in °F
Fuel % 1.3
Water % 0.0
Insols% 0.5
TBN 2.2 2.0 2.3
