A - OD (Inches): 3.82
B - Thread Size (Inches): 1 3/8-12
C - Length (Inches): 9.44
D - Gasket OD (Inches): 2.76
E - Gasket ID (Inches): 2.48
Product Type Description: HYDRAULIC SPIN-ON, DURAMAX
Primary Application: Donaldson HMK04 ASSEMBLY
Media Type: Synthetic
Efficiency Beta 2 (Micron): 5
Efficiency Beta 20 (Micron): 10
Efficiency Beta 75 (Micron): 13
Application Note: SYNTEQ Media #6, Viton Version
Product Group: FH
A - OD (Inches): 5.08
B - Thread Size (Inches): 1 1/2-16
C - Length (Inches): 6.66
D - Gasket OD (Inches): 5.05
E - Gasket ID (Inches): 4.71
Primary Application: PALL HC7500SUT4H, ZINGA
Primary Application 2: SE-25, DCI HBK05 ASSY
Efficiency Beta 2 (Micron): 10
Efficiency Beta 20 (Micron): 17
Efficiency Beta 75 (Micron): 22
Efficiency Beta 1000 (Micron): 23
Application Note: SYNTEQ Media #9
Product Group: FH
A - OD (Inches): 4.77
B - Thread Size (Inches): 1 3/4-12
C - Length (Inches): 11.63
D - Gasket OD (Inches): 3.387
E - Gasket ID (Inches): 3.109
Primary Application: Donaldson HMK05/HMK25 HYD ASSY
Application Note: SYNTEQ Media #7 Viton Version
Product Group: FH
Wix
Product Group: FH
Part Number: 51197XE
UPC Number: 765809521971
Principal Application: Various Caterpillar Applications; John Deere Cotton Pickers. (High Efficiency Version of 51197)
All Applications
Style: Cartridge Lube Metal Canister Filter
Service: Hyd/Transmission
Type: Full Flow
Media: Glass
Height: 8.980
Outer Diameter: 5.094
Inner Diameter: 3.375
Nominal Micron Rating: 7
Gasket Diameters
Number O.D. I.D. Thk.
15114 8 9.025 8.475 0.275
15402 8 6.252 5.852 0.200
Part Number: 51551
UPC Number: 765809515512
Principal Application: Various Hydraulic Applications (10 Micron) - for 20 micron version, use 51552 - for 33 micron, use 51553
All Applications
Style: Spin-On Hydraulic Filter
Service: Hydraulic
Type: Full Flow
Media: Paper
Height: 5.209
Outer Diameter Top: 3.663
Outer Diameter Bottom: Closed
Thread Size: 1-12
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=5/13
Burst Pressure-PSI: 380
Max Flow Rate: 12-16 GPM
Nominal Micron Rating: 10
Gasket Diameters
Attached 2.729 2.415 0.255
Part Number: 51586
UPC Number: 765809515864
Principal Application: John Deere, Toro
All Applications
Service: Hydraulic
Type: Full Flow
Media: Paper
Height: 4.470
Outer Diameter Top: 3.820
Thread Size: 1 3/8-12
Beta Ratio: 2/20/75=10/21/25
Burst Pressure-PSI: 1000
Max Flow Rate: 24-28 GPM.
Nominal Micron Rating: 17
Gasket Diameters
Attached 2.700 2.500 0.100
Part Number: 51621
UPC Number: 765809516212
Principal Application: Caterpillar Excavators
All Applications
Service: Hydraulic
Type: Full Flow
Media: Paper
Height: 6.991
Outer Diameter Top: 3.689
Thread Size: 1 1/8-16
Burst Pressure-PSI: 304
Max Flow Rate: 18-20 GPM
Nominal Micron Rating: 19
Gasket Diameters
Attached 2.834 2.462 0.275
Part Number: 51631
UPC Number: 765809516311
Principal Application: Sullair Compressors
All Applications
Service: Hydraulic
Type: Full Flow
Media: Glass
Height: 5.477
Outer Diameter Top: 3.698
Thread Size: .974-20
Beta Ratio: 2/20=9/17
Burst Pressure-PSI: 455
Nominal Micron Rating: 11
Gasket Diameters
Attached 2.834 2.462 0.255
Look at the size of this thing. Now factor how many PureOne's you could fit into it. It should only take 3 or 4 to handle the volume.
Part Number: 51849
UPC Number: 765809518490
Principal Application: Hydraulic Element For Pall #HC7500SUN8H
All Applications
Service: Hydraulic
Type: Full Flow
Media: Glass
Height: 11.257
Outer Diameter Top: 5.007
Thread Size: 1 1/2-16
Beta Ratio: 2/20=2/9
Burst Pressure-PSI: 340
Max Flow Rate: 28-30 GPM
Gasket Diameters
Packed 4.762 4.484 0.139
Packed 5.140 4.750 0.185
