- Joined
- May 27, 2002
- Messages
- 624
I have an HP Pavilian P6000, model p6670t desktop computer running Windows 7 Home Premium. I have SpyBot S&D 2.0 which started causing error messages. On 10/9/2013 I installed the 1.6 version thinking it would overwrite the 2.0. Didn’t work that way. The 1.6 version works fine, I cannot get rid of the 2.0 version. I did an uninstall using IObit Uninstaller. IObit shows that the 2.0 is gone but I’m still having problems with it. When I go to Control Panel/uninstall Programs it’s still there, right along with the 1.6 version. I cannot get rid of it there. I’ll try to describe what I’ve run into with this:
When I boot up my computer I get the following message: SDCleaner. The program can’t start because rt150.bpl is missing from your computer. Try reinstalling the program to fix this program.
Right behind that I get the following: SDtray.exe. The program can’t start because rt150.bpl is missing from your computer. Try reinstalling the program to fix this program.
Right behind this I get again: SDtray.exe. The program can’t start because rt150.bpl is missing from your computer. Try reinstalling the program to fix this program.
Somewhere along here I get a prompt shown as: Open File – Security Warning, then the message, “Do you want to run....files\content.IE5\614R6IKU\spybotsd-2.1- SR2.exe. I run this thinking I might get it fully installed and maybe then I can get rid of it. It then tells me, “Uninstall previous installation Messages file “C:\Program Files (x86) Spybot – Search & Destroy2\unins000.msg” is missing. Please correct the program or obtain a new copy of the program.
I still have the Spybot 1.6 and it seems to work fine.
Thanks and my salute to someone who knows how to handle this. I’ve worked on this for 3 days and haven’t found a solution. I can find references to some of the error message on Microsoft.com but the limited information there is no help to me.
I use my computer daily but I'm not a master with it.
