I drained, flushed & filled my 2004 Ford Taurus today of the factory fill with 96K on it. It drained a reddish/brown color. I then added 2.5 gallons of distilled water and ran the car up to operating temp and drained this out.
I then refilled with a 50/50 mixture of Prestone Extended life and distilled water. Now, the overflow container smells of alcohol. Not just a little bit, but enough to make your nose burn if when you look down in it.
Is this good???
Is this good???
