Vehicle: '98 Ford Windstar 56K miles
Reason: Power steering fluid left a grey stain on checking rag, concerned about metalic particle contamination.
Procedure: Ran motor and turned steering lock-to-lock several times. Stopped motor. Removed hose from power steering cooler and allowed fluid to drain, removed fluid fill cap, the fluid drained relatively slowly. Reconnected hose, refilled power steering pump and replaced cap, it took about 8 ounces each refill. Repeated procedure untill I used about 2 quarts of power steering fluid.
Conclusion: Power steering fluid appears better but it's still dark. I may repeat the procedure with another 2 quarts of power steering fluid.
